999cc fire mpi?
999cc fire mpi?
smokeme
Established member
Lisbon-Lourinhã, Portugal
Does anyone know if there is an mpi version of the 999cc fire or how hard it would be to retrofit one off another engine.(disregarding ECU stuff as i would simply use a stand alone management)
Dunno...But yu could use the head and plenums from a Punto 75 (1242cc MPi FIRE) engine..
I would bloody well hope they line up...I swapped a 75 head off and exchanged that with a 55/60 head and its fine...so I assume the same would carry for the 999cc head.
So any news if it works???? cause im either after MPi or twin carbs but twin carbs will be a ball ache. cause i was thinking off a punto 1.2 but then i'd need the ecu witch is set up for a 1.2 but mines a 999cc.
Sorry i never saw this thread again!!Yes it does work, you can't use the 1.2 ecu because the fuel AND ignition will be off. I used megasquirt, it's really cheap and completly reprogrammable with a pc/laptop.
here is the version i'm going to use now.(fuel and ignition)
http://www.megasquirt.info/ms2/
and here is the version i had (fuel only)
http://www.bgsoflex.com/megasquirt.html
hope this is of any use, i'll be placing a page on my site about the efi conversion later on.
