Hi All,
My 2005 Fiat Punto 1.2 Classe is continually blowing the 7.5 amp F16 fuse in the engine compartment. Then the dashboard shows the orange immobilizer padlock light leaving it possible to crank the engine not start - nor will you hear the normal operation of the fuel pump for the usual couple of seconds after you turn the ignition on. I don't think the dashboard gauges operate either when this fuse is blown.
I think this fuse feeds the ECU and possibly a few other items. When it blows the car just dies on the side of the road. If I replace the fuse it sometimes blows immediately on turning on the ignition or it may not blow again for days, so frustrating, it's like an intermittent short somewhere.
I'm struggling a little to get the correct wiring diagram but it would be great if someone could put a finger on the normal cause of this problem. I have tried a 10amp fuse but no better.
Any help much appreciated.
Irlanski
Irlanski
