55 Reg Grande Punto Rear Light Cluster
BroodingHat
Hi everyone,
New to the forums but I was told to check out a problem I had with all you lovely people :).
I have had my Grande Punto for a few years now with small costing fixes & large costing fixes (Electric power steering pump :'()
I have had a niggling issue with my rear passenger side cluster for a long time, and from time to time as usual it appears to fix itself but it continually comes back.
Essentially there is a lot of corrosion on the female & male plugs which are on the car & the cluster itself, i have had a new cluster fitted and the issue keeps occurring.
Just wondered if anyone else has had a similar problem and what the possible fixes are?
I have tried removing the corrosion, but scraping it, using a lubricant & also my dad tried using a nail file in case that might be a little more accurate.
I will also add some photos to show what I am talking about.
This effects my break lights & indicator only on the left and i have checked the fuses and everything is fine apart from the 2 sockets.
Let me know if you can think of anything or if the part needs swapping out?
Also if this is something that will need to be done by a dealership or a good garage.
Thanks for your help in advance!!
Hi Varesecrazy,
Awesome, i had a look through but could find too much info on this.
I will have a look through, i have tried cleaning it up but to no joy. I will have a look through to see if there is anything more.
Thanks again for the help!
Hi Varesecrazy,
check the links + do a SEARCH,
failing that get a section of loom + clip from a breaker, and replace your dodgy one,
Charlie
