General 2015 X250 3.0 Selespeed cfc348 (comfortmatic) SHOCKINGLY COSTLY REPAIRS
Code Breaker
London
Hi All, ok some of you will know I have had this vehicle a year now. I have had a lot of setbacks with life with the sudden loss of my best friend last year after me buying this vehicle. He was supposed to do the labour on is as I am physically unable/limited to. It sat for a year on my driveway and all I had done to it was a 'very expensive' injector replacement as old one was seized/rusted in and couldn't be removed, (repaired scuttle water leak issue immediately).
So, a few weeks ago I brushed myself off and decided to get my teeth into it to keep carrying on with my friends and my dream. I took it for MOT and they failed it on brakes which was unsurprising as the discs had a layer of surface rust, me being me decided to replace the lot with all new discs, pads and shoes on all four corners. Big mistake! as then it failed a re-test as I couldn't drive it without MOT and tax to 'bed them in' to pass MOT, long story short, after an £850+ cost I now have a new MOT.
On to the next issue, whilst on its first [short] drive to mot centre, it went into Neutral itself a couple of times and I thought it was me not having experience of this vehicle but the DTC showed as P0919 (Selection and engagement position sensor).
However I decided to take it about 8 miles to pickup something and on return journey it started warning on gearbox, kept coming out of gears, the I noticed it would skip gear 3 and go to gear 4, then no traction, then slipping in gear thudding back in!. Managed to gently convince it to get me home with a lot of worrying.
I looked up the gearbox DTC and it said P2905 - Gearbox Sub-system.
NOW sit down for this part, this is a Minibus with ONLY 43,000 miles!, it has had following already spent 'ONLY' on the comfortmatic gearbox:
Oct 2019 - £5015.93 AT ONLY 31,762miles!!
Feb 2020 - £3180.00
Sept 2021 - £720.00
Feb 2022 - £9600.00
THATS A MASSIVE COST OF £18,515.93 spent ONLY on the GEARBOX! yes you read that right!
I now need to get this sorted and was wondering would there be some sort of resetting that would be needed due to it being sat for a year and be causing this?
Any help in next step I would need to do would be very much appreciated as I'm trying to soldier on with constant forces pushing against me.
Model
Fiat Ducato, x250, 16+1, 2015,
2015
Mileage
43
Firstly reading your other posts I am so sorry you have had these issues but hopefully will be on the road soon.
1) Add an additional earth strap to engine
2) check the small clutch bottle (1/2 to 3/4 full)
3) Ignition on - does hydraulic pump build pressure
4) IGN on/ engine off. Foot on brake.
Can you change gears 1st, N, Reverse, back to N, back to 1st then through the gears once more
This will tell you that there is pressure in the system & the pump is working when pressure reduces & pumps up again.
5) check all connectors for corrosion. This is a common fault.
There are other things that cause this issue but you must do the above first.
Owning a Ducato your best investment is Multiecuscan. With a Comfortmatic gearbox then Multiecuscan is a must.
Your invoices do not show any part numbers. You need to get these numbers as you don't want to go changing parts that have already been replaced.
This info will be handy now & in the future.
Dual mass flywheel - replaced or within spec
Clutch, pressure plate & Concentric slave cylinder
Any other parts replaced?
I would also be questioning what a "reconditioned clutch is". Was this your clutch with only 43,000m on it just cleaned up & put back in because it was in good condition? If they don't want to tell you any info ask them what warranty you have on the clutch kit.
These gearboxes are strong. The issues 99% of the time are electrically &/or the Selespeed unit.
I see 32 hours labour on the 1st sheet, could well be that happened on the last sheet also..
A little concerning it had at least
2 x "recon clutches",
But it's use as a minibus may be something it never does as a camper.
You obviously have access to a decent code reader,
but I agree MES would make sense, as some of the codes will be Ducato specific
Thank you for the replies, as you can see I'm being tested to the max, my partners given up on it long ago, but I'm still hoping to get it going right. I am able to borrow MES when I need from a friend and I've been reading the codes with that.
These bills were whilst vehicle was with last owner and I dont see how I can go to the garage as I didn't own it when they repaired it.
I will do what Kahcorp says and get back to you, but please bear with me.
Ok tried to have a little look at it today. I wasn't able to remove the heater air intake as it was loose but wouldn't come away(?) And didn't want you break it. The fluid in the black cap is completely full, the smaller cap I couldn't really get to but did manage to take a couple of pictures, the vehicle is parked nose up as driveway is at an angle, it appears there is lower fluid than I expected, can't see the markings and you might be able to tell from attached picture.
1, trying to find suitable earth cable.
2, took pics of small bottle I think it's low?
3, how will I know or to tell this please?
4, yes I can go through the gears, and can hear faint clicks whilst moving through gears sat in drivers seat and display shows correct gear
5, still to try and do this
The level in the rectangular container gets lower when the hydraulic pump pressurizes the system, e.g. when the drivers door is opened or when the ignition key is turned. When ignition is off and drivers door not touched the level rises again, but slowly. The max level indicator (arrow) visible in your picture is for either one of these states, I don't remember which. The level shown in your picture looks pretty normal to me, i.e. similar to what I see in my Duc.
Does the gearbox have its own separate earth, or does it use the engine one? in gearbox parameters in MES it was showing 11.4 volts and in engine 12.7 volts, I did plug a charger on it and it started to rise eventually in gearbox, will check it again and compare the two in a few hours.
So scanned vehicle, no faults registered in gearbox. Looked at parameters noticed it shows 'Gearbox/clutch self calibration Not Performed' I am hoping that this may be the cause as components may not know where they sit till this is done? also is it safe to do this calibration and will any other procedure need doing when doing this one like clutch drain?
Another thing is the drivers door shows closed, this is a minibus and has no drivers door but a plug door (which was open)
Readings as below.
Hi
Everything is normal there as per many readings I have saved on various year models.
I have had a brand new battery fully charged & it showed 11.6v.
On another vehicle with few year old battery sitting for 4 weeks it showed 11.9v which is the highest I have seen
I don't know why there are these anomalies.
To start with I believe it needs more oil, I have looked to get the Petronas Tutela Fiat marked but can't source it. I have seen this which shows as same spec, has anyone used this please? it is marked as 9.55550-SA1 which is exactly what is written on the Petronas labelled one too.
I use Fuchs synthetic oils in all of the engines & gearboxes I work on & service. I do change fluids more regularly than most as it gives an early indication of any issues.
Gearbox oil 75w80
Hydraulic fluid ATF D3
Clutch fluid Dot 4
But none of these are for the cs selespeed I think?
You need these from shop4parts
One is brake fluid for the clutch actuation and the other is for the hydraulic fluid to select gears. These are what i use on my ducato motorhome.
