Hi again
It’s been a while no issues but just wanted to clear this part up incase anyone has issues like this
So you mentioned the clutch solenoid valve wasn’t operational on 0mv but after a few chats it seems it will always be on 0 like the other 2 below it are also on 0 has the vehicle is in neutral
If I place it into drive the clutch will active and data will raise up from 0 that’s my understanding ?
Odd gears solenoid valve EV1 = 1.3.5
Even gears EV2 = R. 2. 4 . 6
Clutch solenoid valve current Ev0
So this leaves the one in question
| Solenoid valve current at zero flow |
Which is this based on which solenoid Evo again but at zero flow? It’s a little confusing don’t you think ? I had to come back and comment because I still haven’t had time to change Evo solenoid yet but had no issues since either
