Technical 2014 Fiat Ducato Digital Climate Control Unit
NZGrahamO
Hi All
I have a problem with no power supply to the digital climate control unit on my 2014 Fiat Ducato.
This is bringing up a CAN fault the digital climate control unit has not been seen.
Electrical drawings I have show a Fuse F39 ???? supplies the 12 volt to the
digital climate control unit.
It could be that the electrical drawings I have are pre 2014.
Does anyone know where the supply fuse is located for the digital climate control unit.
I cannot find a F39 fuse on the documents supplied with the van.
Thank You
Fuse designation often seems fairly random for Ducatos, not necessarily lining up with documentation.
FWIW, however, 2014 and 2015 manuals I have copies of here both designate F51 in the dashboard fuse box as protecting climate control.
...and, to add...
2014 was the changeover to X/290 (to which my post above refers). If it is the previous X250, then F39 appears to be the designated suspect.
The info and diagrams available here:
https://fuse-box.info/fiat
...should allow you to identify the location of F39 (and also adds weight to F51 being the appropriate fuse for the later model).
Just like to say thanks the people for their information re my Fiat Ducato problems.
Having a Ducato that is a 2014 facelift model causes heaps of problems getting info re electrical drawings as the e learn info is generally for pre facelift models.
Graham O
NZ
Graham O
NZ
I think after around 2015 fiat moved all technical info to there very expensive online subscription service that's can only be accessed by vat registered garage's
