You are going to gain 25% more power now it will run on 4 cylinders rather than the 3 it has been running onJust had a call back from the garage.
They also put the new coil pack back on, no change, did some more diagnostics and found one of the injectors not working.
It's bee replaced and MOT passed.
more updates later.
I was very wrong about having a big hole in the exhaust causing the high emmision lambda reading , the cylinder with faulty injector was pumping fresh air into the exhaust causing the very high calculated reading by the mot test machine.
