Technical 2011 Panda, problem with brakes (abs esp asr)
Elic25
Hi
So my brother in law bought a 2011 panda manual tm. It had the common issue with the rear brake light, the connector pins was loose and heated up.
So he fixed it, but right after that thr abs light come on.
We managed to find a blown fuse 7.5amp in the interior fuse box.
After replacing the fuse, and since then, the esp, asr, abs and parking brake lights are on, and none of this functions work.
I tried to find another fuse blown, but none.
The brake light works fine.
I dont have access to a professional scanner.
Someone know someyhing about this issue?
Thanks.
In this instance you’re going to need to get it plugged in and diagnosed.
It’s impossible to say without diagnostics what is causing all these lights to come on.
As the problem appears to have started with the tail lights its possible there is still a fault in there, so its well worth having a very close look, maybe take the light clusters off the car.
If you have a Windows laptop, www.multiecuscan.net will give you all you need for electronic diagnostics. Get the OBD connection cable(s) from MES as there is a lot of rubbish on eBay. The costs for a registered version and cable will be about the same as one scan session at a garage so its well worth getting tooled up.
Hi guys
I connected a foxwell 660 scanner, and when it looked up for all the systems faults, it found none. The problem is that when it got to Abs Asr check, it had no communication and just skipped on them. Any ideas??
No faults, at least.
