- Joined
- Sep 14, 2009
- Messages
- 19,492
- Points
- 3,295
Gearbox shifter shaft seal.
To get access you have to knock out a roll pins and remove a C washer that hides behind the non tapped nylon spring seat. The old roll pin (4mm x 25mm) was in two pieces. I carefully slid out the shaft hoping to keep the springs in place but the lighter spring always makes an escape bid. Cover it with a rag or lose it. I levered out the old seal, tapped in the new one and reassembled the mechanism. Then Oh ** I only had the shifter lever 180 degrees out. Oh well, at least I have a spare roll pin.
That new (now old) pin would not shift. My trusty pin punch was getting wedged into the roll pin so I bought a new set (£8 so not too bad). Still no joy. A friend with a press had a go but we could see the shaft springing so gave up that idea. I was now faced with a considerable problem.
Overnight, a thought came to me - Maybe my 4mm punch is a bit too large for the hole and it is longer than necessary. So I cut the punch pin to 20mm and carefully ground it down to 3.95mm over about 1/2 that length. IT WORKED that nasty pin came out, but OMG it was tight. I got the last 50% out with my older (and now quite wonky) smaller pin punch. The roll pin had bent banana shape. It went in seemingly OK a bit tight but it was new so not unreasonable.
Basically DO NOT MAKE MY MISTAKE when doing this seal. The roll pin hole is not quite on the centreline but you wont be able to see that its wrong. Fit the shaft upside down (a very easy mistake to make) and you'll have a whole world of struggling. You cannot knock the pin out from the other side it has to keep going the way it went in.
The upshot is no harm was done. The new pin went in nicely and everything leaned up. The shifter shaft slides works as smoothly as ever. I even wrapped the bare end with a strip of thin nylon cloth and two zip ties to keep grit off the sliding shaft.
