Technical 2006 2.8 JTD Fiat Ducato Temp Sensor and Sender
IceVovo
This is more for information.
Been doing some testing of my coolant temp sensor.
They are located near the thermostat housing.
You need to remove heaps of pipes to see this properly.
Here is a pic of the Temp sensor and Temp sender for those interested.
The temp Sender is brown and this connects to the the dash temp gauge.
The black one is the Coolant Temp Sensor and connects to the ECU.
...which turns on the radiator fans when required, etc.
Hi, I'm having an issue with my temperature gauge and I want to change the sensors.
Could you tell me the OEN for both??
Thanks.
