Lotus26R
Has anyone experience of removing/cleaning the EGR on a 2.0 JTD please?
If so, which bit is it that gets gummed up, and what happens when it does?
On our Smart, the soot/tar build up in the valve reduced the effective size of the intake so radically reduced the engine power. Cleaning the gunge out restored normal performance instantly.
On our Ducato, the valve seems to operate normally. I assume that the exhaust gas then travels down the pipe, through the cooler and into the intake manifold to be sucked into the engine. Even if the valve/pipe/cooler gunged up completely, I'm not sure how that would harm performance - wouldn't the engine then just breathe clean air and be better for it? I guess EGR blanking plates do just that. Does the gunge accumulate further downstream (ie, in the manifold)? if so, how would we clean that out?
Has anyone had success with diesel fuel system cleaners or are they generally considered to be snake oil?
