ninjagordy
- Joined
- Apr 1, 2013
- Messages
- 10
- Points
- 3
hi guys ,
having loom issues as in when the engines cold limp mode, let it warm up, clear codes and it runs like a train all day!! the codes it keeps throwing is fuel pump relay circuit malfunction , pc008 . there was a broken wire on the ecu plug which I replaced at the plug by soldering to the pin and connecting to the existing wire. now when the codes are clear the van goes fantastic but it goes into limp mode when its cold which i cant understand why as when its warm its fine as said when the codes are cleared. I have replaced the relay (passengers wing) so im thinking more likely a wiring issue possibly. does anyone know where i can get a used loom, my plan is to hopefully get a good loom and swap them, then check and repair the old loom as required. or , if this sounds familiar to anyone and they know what it is...feel free to let me know!!
fiat want a grand for a new loom which is crazy!! the loom has the large single ecu connector not the 3. engines the 16v unit.
