Hi there... Having problems with my ducato and would be grateful for any assistance...
- Very reluctant to start from cold and needs a lot of cranking... When does start loads of white smoke
- glow plug switches on and off normally when preheating, but flashes for approx 60 seconds after starting. Understand this indicates a problem with the pre heat system.
- can hear relay click on and off as it should
- voltage between battery + and bus bar is 12.5V with ignition on and does not seem to change when preheating
Any thoughts on further fault finding steHps? Am I right in thinking there doesn't seem to be current getting to bus bar? Could this be a dodgy relay or broken wire?
As you might be able to tell electrics not my strong point - appreciate any help!
Thanks, Richard
Thanks, Richard
