Snowey1
Hi all
My glow plug relay on my 2007 X250 Hymer doesn’t clic on and the glow plug light on the dash only illuminates only for a split second. The engine is near impossible to start now the colder weather is here and I need to get the Glow Plugs working. I’ve tested the plugs as per the forum here and they have a 1.7omh resistance (same as the new Bosch ones I bought just in case). My question is if I have faulty glow plugs will the ECU stop the relay working? I’ve checked Fuse F11 and that is ok , I’ve not checked the relay earth yet. I’ve taken the cover off the relay and pushed the contacts together and I can hear the the heater fan slowing down so current is being drawn by the plugs although it still doesn’t start straight away like it should. I did think to strip it down and just test the relay with the new glow plus just temporarily attached. Sorry forgot to say I have tried a new relay and no change. I know you’re all saying just put the new plugs in but as they’ve never been touched I’m expecting them all to shear off, and as it’s an A class access is nigh impossible.Any help would be gratefully received.
