MazCinq 100% fiat addict Parked in the garage Joined Mar 27, 2010 Messages 1,847 Points 485 Location Nottingham Jan 19, 2014 #1 ok thinking of buying a stilo 1.2 16v and apparently the timing has jumped, I know the 8v is a Non-Interference engine but just to jog my memory, the 16v IS an interference engine right???
seicentoceeney Member Joined Aug 19, 2012 Messages 204 Points 53 Location Leicester Jan 19, 2014 #2 Yes it is, could have bent valves and possible damaged cam, amongst other things. Most twin cam engines are interference!
Y ycming Patron member Written a guide Joined Oct 13, 2006 Messages 10,261 Points 1,600 Location Glasgow Jan 19, 2014 #3 If is cheap enough why not. Before i do anything i would correct the timing, and do a compression test. If is one tooth could be ok ! Ming
OP OP MazCinq 100% fiat addict Parked in the garage Joined Mar 27, 2010 Messages 1,847 Points 485 Location Nottingham Jan 19, 2014 #4 03 stilo for £200, worst case it needs a new engine which isn't too bad is it?
