Technical 100hp timing woes
Replace the connector, it is the same for any fiat that used the same ignition coil as your panda.
Plus refit your cam belt covers
I do want to replace that entire loom. All the wiring seems to quite brittle though. On most of the offshoots of the loom the heat sheaths have broken off or melted.
Yes going to replace all the covers. Ran out of working time and i made the mistake of putting the aux belt and crank pulley on before putting the lower cover on. So i have to redo all that when i can... but of-course the weather doesn’t look like its going to play ball this weekend.
dave the kit you posted seems to come
With a crimping tool so will look at getting that... will it fit correctly though?
Dave the kit you posted seems to come
I have similar pliers and the same connectors.
They are a fiddle to fit. You have to put the open side of the terminals into the slot in the pliers, then push the wire into the terminal. Use the old terminal as a guide. When you crimp, the end tags are rolled around and into the insulation, and around the copper wires. This locks the terminal to the wire. Don't expose more copper than necessary.
If the wires you are using are on the thin side (e.g. Fiat coil wiring), you could be advised to solder tin the copper end for a better grip when crimped. On thin wires, I tin the wire end crimp and then solder the crimp as well. Belt & braces with a tiny touch of solder. Too much heat spoils the insulation grip, but on fine wires (even with ends doubled back) there's only minimal grip under the crimp.
If you don't mind using just two colours, this high temperature silicone wire from a Yorkshire based supplier will do the job.
https://www.ebay.co.uk/itm/UL3135-Silicone-Rubber-Cable-High-Temperature-Wire-10AWG-to-18AWG/254049272309?hash=item3b268441f5:g:YC4AAOSwliFcK9nh
If you want multi colours, it will have to be from China. Oh Joy.
Managed to sort the rough idle out. Careful use of cable ties and some qbond on the vacuum pipe on the manifold.
I now have a strange issue on the dash. The engine light has cleared itself but I now notice the fuel gauge drops and the light flashes randomly... It will show i have half a tank and then it will drop, the light will flash and it’ll then pick up again. Any ideas what this could be? I heard it may be earths so i cleaned up the two earth points on the ecu and on the injector loom with some sandpaper...
I went back in to do this but I’m finding it difficult to place the cover in the correct location. Does it have to be fitted before the engine mount is fitted or can it be done with it in place?
At a loss here...
Hi guys
I know this is an old thread. But I'm trying to find out what locking tools I need ti change the Cambelt & Water pump on my 2007 100hp.
Can someone give me a link ti te correct tool (s) I'll need to get the job done please.
You need just any kit that contains these bits
1860985000
2000004500
2000015800
1860987000
I haven't bought any recently so don't have a link I can recommend
Quality of china 1860987000 can be really bad, be careful not to snap the pins
Cheers mate for your reply. I've seen a few of those bits in some kits on Amazon and Ebay etc. I'll find the best one I can. The kits are only around 20 quid so we'll worth getting one. 👍🐼
As long as it's running correctly
It can be done without any locking tools by making your own timing marks, this makes it unessery to loosen the camshaft pulley, one less step, one less thing to go wrong
Mark a tooth on the crank and cam pulleys
Transfer them to the block and belt
Copy the marks onto the new belt
Align everything up and away you go
I would still use the lollipop pop camshaft one one as it sets all the pistons half way down the bores, I still use the camshaft lock to double check everything is correct
I used a lock on the exhaust cam. Inlet is connected by gears so you only need both locks when the cams have to come out.
Use this kit
I did not find an easy way to lock the crank. 1.4 does not have a timing hole for a pin to lock the flywheel like the diesel does. The black ring and stick lock plate is only usable with flywheel removed. Pretty useless for a service job on the timing belt.
(1) Set crank at mid up stroke on #1 cylinder. The two rods go into Cyls #1 and #2 plug holes. When they are level the pistons are all in line. Turn the engine clockwise so #1 will be on up-stroke.
(2) Lock the exhaust cam and Tippex paint mark the cam pulley against the engine.
(3) Note crank pulley position and mark that with Tippex paint. It's worth making a wire pointer but I used a casting rib.
(4) Remove the old belt, tensioner and water pump. #1 DO NOT ALLOW CRANK TO MOVE. That said a few degrees are ok its just to avoid piston/valve contact.
(5) Fit new tensioner and water pump and fit the new belt. Use the crank Tippex marks to be sure the crank has not moved.
(6) Tension the belt using the little pin wrench. You need to align pointers on the tensioner itself.
(7) Remove cam lock and turn the engine. Confirm the crank is running on the correct tooth. If belt tensioning has pulled it out by one tooth you will need to relock the cam and refit the belt with the crank set one tooth "out" to compensate. Repeat the belt tensioning and the crank should be pulled into the correct position.
(8) Box up the job.
That's a great write up mate on the job. Waiting for the parts ti come from AutoDoc. Went for a Dayco kit as this is the one that's on it already. Also came with a thermostat included. What's your thoughts on the quality of Dayco compared to SKF or INA kits.
You are supposed to loosen the cam pulley centre bolt before tensioning the belt. Then use a special tool to counter-hold the pulley while torquing the centre bolt. Tensioning the belt with both cam and crank locked will not give correct timing as only one side of the belt gets taken up or one of the shafts moves. That's why I went for the Tippex marks, which show any error. If/when you get it wrong, just set one shaft "out" by one tooth and the belt tension will pull it correct. If the new belt wont time correctly, then you can loosen the cam bolt and do it "properly".
My locks kit has a front crank lock that did not fit and a back end lock that only works with the gearbox removed. But it does have excellent piston setting pins and good cam locks. I made myself a pulley holding tool but never used it on the petrol engines. It was handy for the diesel.
FYI finding the right locking tools for the 100hp is a minefield if you want the camshaft sprocket locking tool.
They are all made in the same factory it seems and changed their output sometime prior to Sept 2024, but all the sellers haven't updated their text description or pictures. Or at least that was my experience in October 2024. Sometimes they have updated their pictures but sometimes not. They will often, incorrectly state that the set is compatible with the 169 Panda 1.4L. That includes higher end sellers like Sealey.
The 100hp engine camshaft sprocket must have Fiat tool number 2000015800 (also written as 2.000.015.800), where the engine block has a hole for an M8 screw for the tool.
Most kits come with a copy of 2.000.004.200, which it entirely different in shape, and uses an M10 screw, which is an easy clue that it's wrong!
So for a 1.4L engine you want the kit labelled as V1 on the attached picture. Be aware many suppliers have changed to V2 so the camshaft sprocket tool is not compatible with the 1.4L engine in the 100hp.
Of course if you are just changing the belt, you don't strictly need the camshaft sprocket locking tool by sing the method of marking up the belt, sprocket etc.
Hopefully this info might help someone.
I ordered about 5 different kits and they were all wrong despite the descriptions and pictures. Fortunately I found an old kit 2nd hand on eBay with the right part.
Evening guys
Mate Changed the Cambelt on the 100hp (Along with water pump and thermostat) today.
I bought some new top and bottom plastic cam covers from Shop4parts but they done seem to fit right compared to the old ones. You can see from the photo that there is a bit of a gap! Would this be a problem or do I either need to re-do it again or go back to the original ones.
Also had a real hard time getting the new Cambelt on over the camshaft pulley - having to stretch it to get it on! Is this normal or should have had to slacken something to get it on easier! Concerned about issues further down the line if the belt has been damaged.
Any thoughts please guys
