don't bother with a video. I am sure it will be the meter
test the battery at rest should be between 12.4-12.8V and 12.6V is ideal.
if its over 12.6V take the surface charge off. Put the main beam on for a few minutes wait a few minutes and retest until its around 12.6V
start the car and immediately switch on as much electrical equipment as possible
flasher
main beam
rear window
fans max
wipers
aircon
radio
and so on
the voltage across the battery should be at least .5V greater than when you started
then check it doesn't drop when turning the steering from lock to lock.
clean the top of the battery terminals with a scouring pad. Measure from the top of the negative terminal to the case of the alternator. Then raise the revs. Should be below .2V. Then do the same from the alternators output to the positive terminal.
flasher
main beam
rear window
fans max
wipers
aircon
radio
and so on
