The 115Jtd fitted to the Stilo, has no wastegate, it is a variable geometry turbo charger, this means there are two sets of vanes, one on the impeller and another set which can rotate around them around 15 degrees. The turbo pressure is controlled by the efi ecu which controls a solenoid, that supplies vacuum to the turbo outer vanes. The signal to the turbo control solenoid is a pulsed width signal so that instead of fully on or fully off, complete control of the turbo geometry can be achieved.
Sorry also should have mentioned the turbo over pressure is controlled by the control solenoid, and if the turbo pressure gets too high and is not controllable by the solenoid (eg in the event of a solenoid failure) the efi system goes into fail safe limiting engine torque to 40% by cutting the fuel supply.
