S sailingswagman Patron member Joined Jan 4, 2018 Messages 12 Points 6 Location Colchester, Essex Feb 2, 2018 #1 1.9D (not Turbo) Glow Plug #1 Does anyone know how to get the plug out? I just can't see how to do it! Followed eLearn and have done 3 & 4 - Easy, 2 - Lots of swearing... #1 can't see how I'd even get a tool on it without having to remove the injector pump or inlet manifold.
R retro64 New member Joined Oct 23, 2017 Messages 1 Points 0 Oct 29, 2018 #2 Yep Im in the same boat and there's no suggestions on here
OP OP S sailingswagman Patron member Joined Jan 4, 2018 Messages 12 Points 6 Location Colchester, Essex Oct 29, 2018 #3 I did figure, in the end, the fuel pump can come off without removing the timing belt. Ultimately I just did 2,3,4 and reset the glowplugs and error codes with a laptop. #1 is still in there without issue.
C cobby58 Member Joined Dec 28, 2013 Messages 91 Points 78 Nov 1, 2018 #4 1/4 inch drive socket set with a 10mm deep socket and a "wobbly" joint. Difficult, but not impossible [emoji6]
