I've no idea, but I'd suggest browsing a few parts listings. If the manifold gasket is the same for both, it is likely the manifold will fit. If the gaskets are different, it probably won't fit, but might.
Depending on where it is going, physical space needs to be considered too.
For road use, decat on anything post 2003 should fail an MOT, as well as try to poison those around it, like older cars did.
