Lozzy08 Happy Days =D Written a guide Joined Aug 13, 2008 Messages 423 Points 112 Location Derby Nov 3, 2008 #1 Simple question - will a 1.1 8v head fit onto a 1.2 8v block and work if we change the cam over?? thanks
J Joif New member Joined Jun 9, 2008 Messages 43 Points 6 Location Anglesey Nov 3, 2008 #2 Should do, Someone Correct if im wrong but the mk1's 1.1 & 1.2's have same blocks just different ECU's?
ilsonemo Speed Camera Tester Joined Dec 6, 2007 Messages 563 Points 263 Location Ilkeston (Derbyshire) Nov 3, 2008 #3 so what is the difference between the 1.1 and the 1.2 ? they both look practically the same is there and easy way of making a 1.1 into a 1.2 ?
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Nov 4, 2008 #4 1.1 has a 70mm bore 1.2 has a 70.8mm bore so you can use the 1.1 head and even keep the cam in it to save re shimming. but you must use a 1.2 head gasket
Ralf S. Distinguished member Parked in the garage Written a review Joined Dec 3, 2003 Messages 4,405 Points 1,137 Location The land that time forgot Nov 4, 2008 #5 1.1 head gasket surely, if the bore is different? Otherwise you have a gasket with a bore bigger than the cylinders. Ralf S.
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Nov 4, 2008 #6 Ralf S. said: 1.1 head gasket surely, if the bore is different? Otherwise you have a gasket with a bore bigger than the cylinders. Ralf S. Click to expand... his block is a 1.2
Ralf S. Distinguished member Parked in the garage Written a review Joined Dec 3, 2003 Messages 4,405 Points 1,137 Location The land that time forgot Nov 4, 2008 #7 Oh yes.. Ralf S.
