Technical '06 Panda crank sensor issue.....
Your problem is here
The blue and yellow
Purple and yellow
Match the diagram
There's no voltage going from the relay to where the arrow is
It's likely to be a break at one end or the other
I would be tempted to pierce the wire in the middle with a pin and measure the voltage, the small hole needs sealing with glue or tape to stop moisture getting in
The blue and yellow
Purple and yellow
Match the diagram
So it means i need to check the outgoing voltage from t09?
Because here on the left you can't see a fuse clamp nor a wire from below so shouldn't there be a break inside the fuse box?
These are the voltage values on the relay and the 2.5v seems off to me does that help?
But my question now is should i track back the 2 wires to wherever they are going to? Because after pulling the fuse box and looking at the cables, i managed to see these 2 going upward behind the battery which probably means towards the ECU loom
I am guessing
All the power sides from the relay are just connected one after another
I have never been inside the fuse box, I would guess there is just a metal bar,
And that's got bent
I am struggling to find some pictures at the moment
Well what we need to know is which side is the feeding side on the fuses? Because as far as i know it should be left side and the right will take to the powered component now i can simply crack the fuse box open but i wanna be sure if the issue is within it because i don't wanna crack it open and have to rearrange all the relays and fuses in their respective order
Blue and yellow next to purple and yellow
Are the outputs
Pins 61 and 62
You can double check, pull the fuel pump fuse, the feed side is the side still with volts
I'd do something like this to see if we can get the car going first
Only need the feed (input) from the fuel pump fuse to the coils (input)
Yeah i know and i can even take the power directly from the battery this way i won't overload a fuse or relay
Yes to test with, use a fuse though as the rest of the circuit is still unknown
Not the only way
But this would be safe
But It will not power off with the ignition so you would have to disconnect it
Hi there again sorry for being this late just checked right now i am getting battery voltage for 2 seconds after the ignition gets on then flattens out at complete 0v then when i crank i get battery voltage again
Fuse F17 and forgot to mention fuse plugged and unplugged which means voltage is being sent on ignition and crank
