The chassis is a factory one unless it was added from another car because it has an italian fiat label on it so it's definitely not an aftermarket one or hand madePut it back as it was
I am fairly sure the one to the chassis has been added to fix a problem but will check the diagrams later
We had 0.8V between the ECU and the block, and 0.2V between the block and the battery
0.2V is good carrying 100 amps
1V is bad carrying less than 5 amps
Either the test was wrong or we have to investigate further
Great.Yeah it does have A/C
It's about the only bit from the builtin we haven't already doneDidn't check the code but it doesn't come back immediately gonna check it again and i did give you the gap I think it was 1.25mm
