Technical '06 Panda crank sensor issue.....
Yep that fine
Let's look at these two earth straps on the ECU
The main beam relay does not look to be fully home
It's not your problem though
Have you pulled every one out and pushed them back in the same place
The ECU really has been swapped in the past
Yep that fine
It's not your problem thoughView attachment 440027
Yeah i went and checked every single one of them but one at a time and of course each one was returned to its place probably didn't push that one all the way in.
Sorry my bad
As for the ECU I can't be sure but not only it might be swapped but it might be inversed aswell can't be sure though unless someone that is absolutely sure about it
I'll remove the ECU and tell you what I mean tomorrow because it's dark and hard to take pictures
No no i mean the ECU the way it is fitted is probably rotated 180 degrees probably because of its back
Still need the voltage drop to the ECU aluminium housing whole cranking
It was the only only thing we measured that was wrong
Was the test wrong or is the problem here somewhere
Want me to remove the ECU from its place and test it mid air?
Because the back cover is probably touching with its fixing location because as i told you it's probably rotated a half turn
These are the 2 wires attached to the ecu case on the bolt we moved it to the upper left bolt but initially it was on the bottom left one
See what i mean rotated half a turn? I'm worried that the ECU got fried because of that
And about the fuse box everything is seated properly, double checked everything and they were all properly seated in their places and what seemed off were their plastic casings even the fuse
Almost certainly the ECU and body computer is fine
I wish I had the same layout even though mine is a euro 5 its wire completely different
Two grounds on the same place causes ground loops, it's not standard practice, the only time I have seen it is where one has failed and a second added
It looks to me like the both go into the wiring loom
I suspect one was somewhere else
Ok so want me to separate them?
And no, one goes into the upper loom and the second as you might have seen in the picture goes under the windshield to the chassis
If it's bad to put them together I'll put one on the left upside and one on the bottom left side no biggie
but what about the ECU? Is it inversed? Or am i only theorizing stuff?
This photo is taken how it is fitted just removed the 4 bolts and laid it down so i could properly take the picture and explain
Wait a minute how do i do it for the one in the loom? Or want me to do it on the bolt after assembling it again?
Put it back as it was
I am fairly sure the one to the chassis has been added to fix a problem but will check the diagrams later
We had 0.8V between the ECU and the block, and 0.2V between the block and the battery
0.2V is good carrying 100 amps
1V is bad carrying less than 5 amps
Either the test was wrong or we have to investigate further
