Hi guys, since 6 months I have a big issue with my selespeed gearbox, here in Kosovo I can't find at least on mechanic who understands selespeed so I tried a lot to fix it by myself but no result, first I purchased new accumulator from Germany I replaced it but again pressure drops fast, after reading on forums I tried to replace EV0 valve someone told me that if there is a leakage the pressure will drop fast etc but again with no result, so please if anyone had similar issue and have fixed his own car can please share it with me, below I'm gonna give you some symptoms that I have in my car
1. Pressure goes up to 51 Bar, and drops when car on idle for about 40 sec to 1 min.
2. When I open the driver door in the morning it primes for about 3 sec, this means that when car is off the pressure is holding.
I did many procedures like cluch drain, calibration goes well, so I'm stucked because I worry that my pump will go away so soon.
I expect some help from anyone what should I check else, and what is the normal priming period when car is on Idle ?
Thanx.
Thanx.
