Technical  Stilo Abarth Selespeed Problem P1772
Istanbul
Hello everyone from Turkey.. I live my life with the only stilo abath in my country. Or rather, I continued. my problem started after I overhauled my engine. My vehicle waited for a long time with my engine dismantled. Then when we put the engine on, the car started, but the gear did not react to anything. remained in its vacant position. and we started our adventure. I changed many parts. sensors, engine and robot wiring,new potantiometers,new turbine speed sensor, pump, actuator,new pressure tube, oils,new selespeed relay,new fusebox, new clutch and new clutch bearing,, gear lever, engine ecu, new selespeed ecu, everything you can think of. All values are normal, regardless of when the vehicle is warm or cold. Like the value between 45-55 bar. there is only one error and I could not find which sensor or part the error belongs to. error code P1772. I am no longer able to form a fiction in my head about what could happen. I will replace the complete robot system shortly.
Thanks in advance for any information sharing.
To reach me, you can reach me either here or via whatsapp.
+90 532 783 97 31
P1772- Shift Lever Position Sensor - Function Faulty
Low Oil Hydrolic Pressure
Gearshift Lever Switches ( one of 4 )
