Hello.
I have a question related phonic wheel self learn process. I can't find any topic what is started about this issue thats why I made my own.
My Stilo MW ( 2003, 1.6 16v 296.000 km) got some engine refurbishment. After that my Idle was really bad. I changed the Lambda sensor (Pre Cat), 2 ignition coil from 4 ( cylinder 1 and 4), I changed the throttle body, changed the ECU ( I had a second for spare ) but still de Idle is not good(connector cleanings, spark plug setup, etc). It can keep the rev at 750 but sometimes drops to 500 and 2-3 time from 10 the car stall. I find that the throttle body zero position was not good so I made the zeroing procedure and while I checked almost every parameter in MultiEcuScan I found that the Phonic Wheel Self learn is says "In progress". I tryed to do it properly but it seems I can't do it in a right way because the status not change to Completed. Even I follow the insturctions written in MES.:bang:
Is somebody have similar experience?
Can this cause idle problems?
Ps: My last plan is to check the cambelt. That was changed as well and maybe it is missplaced with a few tooth.
Thanks in advance and Happy New Year to everybody.
Br. Gábor.
Br. Gábor.
