For the past few weeks I was at the beginning ocassionally getting a "check LHR turn signal check LHR fog lamp" but only while braking. It has now got to the point that turning on the side or dipped beam causes the entire light cluster to short out and the reverse lamp on both sides is lit dimmly while the right cluster otherwise continues to work as normal and the left side is otherwise completely unlit. I took both clusters out today to find this burn damage:
Where do I start !?
Where do I start !?
