which puntos has 6 speed gearboxes, which would fit my punto mk1 ? do i have to do some modifications on gear shift mechanism?
Just out of curiosity. In case ill spot one.
I think the 1.2 16v ones. Pretty sure these will lower the gearing, so it's not necessarily the "go faster" tweak you may assume. Of Punto linkeages, I know nothing.
If you find a good six speed box get the lever and linkage to go with it. But as said its pretty pointless - unless the engine is souped up with fast cams and a narrow power band.
