I have a shorting on my 98, 1.2 Punto. I have solved the problem temporarily by disconnecting the positive every time I stop. The problem is not the battery as when I reconnect the battery after 2-3 days it starts sweet as a nut. When I have found which circuit the fault/shorting is on, i.e. Lights, heating etc, by using a ammeter and removing the fuses one at a time, I just want to know how would I repair this? re-wire the loom the fault is on?
Also, I have got new battery terminal clamps but I need to remove the old clamps which have a pincer-like, which are tightened on with pliers, clamped on to the positive cable, What is the best way to remove these old clamps?
Thanks,
Allen
Thanks,
Allen
