Technical Cant tension tensioner as the bolt spins.
Are you talking about the cambelt tensiiner bearing seccentric mount for the timing belt ?
Just a thick washer on an 8 valve FIRE
Remove the washer and bearing.. check the thread ;)
Torqued it up and the tensioner slipped damaged valves I suspect.
How do you replace the stud? Can you even replace it.
****. Bad news as you have the 16V
My tensioner nut was a fancy gold coloured thing with a coil inside and then a thread just in a small nut. I wondering if somebody had recoiled the nut! but somebody told me it was a fancy one use nut. I had used it about 3-4 times before finding the spring was doing something weird while torquing. I had no idea it was even inside the nut. So I was just very lucky!
It is a bit crazy the top part of the engine relies on this one nut. I replaced with an ordinary nut. I suppose it is worth trying to get a longer stud and putting a lock nut on it.......thinking about it now I might have used locktight....
You will need to check for bent valves..
Once you know its worth continuing.. YES its a STUD for a reason.. like the exhaust manifold studs.. they are designed to be easily replaced
Just replaced the head gasket -.-
Where can i buy the stud, do you have a link for one? How does it connect into the head?
Here you go: https://www.youtube.com/watch?v=dRUxyosjzoM That's how it's done!
Where to buy one? there are stockists of engineering supplies who I'm sure would match the old one if you took it in to them. Don't however, use one out of a cheap box of bits from the likes of Aldi/Lidl etc, it's going to be at least an 8.8 high tensile steel - see here: https://www.fastenright.com/specials/materials-and-finishes/high-tensile-steel but, unlike a bolt head which has the number on it, a stud won't be easy to establish what it is as it's not marked. Maybe the way to be sure is to order a new one from your Fiat Dealer, it won't be all that expensive compared to the peace of mind you'll get from knowing it's the right one.
All this talk of how to source and replace the tensioner stud but here (above) in the third post in this thread, you say you suspect valve damage? If this is the case your tensioner stud is going to be the least of your worries!
Have you checked for bent valves?
He responded to the last guy asking that question by saying he had just replaced the head gasket and then he was back into wanting to know about studs
:D
Thanks, yes he did, but I'm not clear as to whether that was because he'd been rectifying bent valves or just because the gasket had blown? It's a strange way to word it if he'd had the head off because of bent valves?
