Old 20-02-2021   #1
Inner anti-roll bar bushings
I've just seen that the ball joint rubber where the control arm meets the wheel hub is split. It's new lower control arm time.
Since the anti-roll bar has to be disconnected, I might as well change the rubber bushings. The outer ones (near the wheel that bolt to the control arm) seem simple enough. How do I swap the inner ones though (the ones that are attached to the subframe)? Do I have to remove the anti-roll bar completely and then fight them off?
Cheers for any advice, guys.
quaffle is offline Reply With Quote Quote
Old 20-02-2021   #2
judderbar has donated!
Finland
Re: Inner anti-roll bar bushings
If the ball joint is OK you can get some after market rubber boots. Saves you the hassle of alignment.
On the Bravo the ARB bush clamps can be chiseled apart or drilled. Punto is likely to be the same.
https://www.fiatforum.com/bravo/4635...rm-bushes.html
judderbar is online now Reply With Quote Quote
Old 21-02-2021   #3
Outer bushes are easy enough if changing the control arms as you’re putting new arms on, then put new bushes on as well and I’d recommend using new bolts.
As for the inner ones, be very cautious. Firstly the bolts like to shear off in the subframe and then you’ll spend a very long time trying to remove what’s then left stuck in the sub frame. On my old mk2b I ended up drilling them out with colbalt drill bits then had to replace all the bolts again with new ones.
I’d recommend spending plenty of time soaking all the bolts in penetrating fluid for days if not weeks before you intend to do the work
Likes judderbar liked this post
Maker and voice behind the YouTube channel PuntoHowTo 12k subscribers can’t be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is online now Reply With Quote Quote
Old 21-02-2021   #4
Quote Originally Posted by judderbar View Post
Thank you for the advice. I didn't know you could get replacement ball joint boots as the Haynes manual says you cannot. Looking on eBay it seem that they are universal boots that you get in a kit and just kind of size up the best one and slip it on.
Quote Originally Posted by AndyRKett View Post
I hadn't considered the fact that they bolts on the inner bushes might be difficult to get out. Do you think it's worth the hassle or shall I just leave what's all ready in place there?
Old 21-02-2021   #5
Finland
Quote Originally Posted by quaffle View Post
I have boots 1 and 4 (from measuring them today)
I got the boots a few years ago. I cannot recall how I went about specifying my order for those boots. They do look about the right size but I only just opened the packet.
Old 21-02-2021   #6
If the inner bushings are ok I’d probably leave them or pay someone else to do it.
With replacement boots be aware that here in the uk the rain water and road salt can very quickly wreck the joint if the boots split. So it may need replacing anyway, and if the boots have perished on one end of the control arm then the bushings on the other end of the control arm may also be badly perished.
If it’s just torn and it’s happened recently you’d probably get away with a replacement boot/gator on the joint
Old 26-02-2021   #7
Thanks, Andy. I just picked up a set of new arms. They were only about £30 each for some ones from FAG (brand). Figured it would just be easier to swap them as I've still got to disconnect the arm from the hub knuckle to swap the boot and that looked just as fiddly.
(T) anti roll bar?? wilko1992 Punto (Mk1) 8 09-04-2012 12:27
(G) anti roll bar and bushings suziesunshine Doblo 6 04-10-2011 19:25
(T) Anti roll bar... pandamonius_maximus Panda (Classic) 33 20-03-2009 10:58
Torsion bar/Anti-roll bar..... Emma FIAT Boo Archives 5 13-05-2007 02:37
anti-roll bar bushings PeteIreland FIAT Boo Archives 3 11-01-2005 12:17
