dubsential
- May 31, 2016
- 91
- 33
Hi, punto jtd 80
My car won't start it will go with easy start but if i just crank it without it will throw a p1320 after its cleared of codes..
I have good fuel pressure for cranking in multiecuscan although when started the fuel pressure is higher than desired, not sure if its the remap..
I checked leak off and one injector is giving out slightly more fuel, I also tried this with the cam sensor unplugged which of course gives the p1320 error straight away, although that states signal not present as opposed to low signal.. however fuel is present when cranking for 10 seconds and measuring leak off.
Occasionally it is throwing a p0190 or p0191 usually when I touch the throttle and it cuts out this is intermittent which I'm wondering is this a sticky regulator and perhaps the reason for the higher fuel pressure.
Any ideas or has anyone experienced the same symptoms, I'm thinking maybe the crank sensor and fuel regulator are at fault here.
Is it worth removing the regulator and cleaning it?
I tried looking at rpms on multiecuscan but it isn't showing anything...
Worthy of note the car will restart when its been run a short while without easy start
