Hello all,
I have a 2000 Mk2 Fiat Punto 8 valve 1.2 petrol manual.
The other day we noticed when going through a tunnel that the dipped headlights suddenly stopped working at the same time (main, sidelights and indicators all fine). I just checked the bulbs and both look fine, I then checked the fuses visually and they looked okay. Then tried again and driverside dipped beam lit up okay, turned on and off a few times and then it stayed off. Went for a drive and noticed it lit up again, then pulled over and stopped engine but kept electrics on, light went out again. So the driverside beam at least is intermittent, passenger seems totally out.
Could this be a fuse or relay issue? or something else. If its fuse/relay can someone please confirm to me which one I should change?
