Hello to all,
I have a 2001 Fiat Punto EXL 1.2 8v, and it current has an issue were it lacks a lot of power. This issue has only happened the last couple times I have driven it and usually does after the engine has been running previously.
For example if I were to get into the car and start it for the first time that day it will usually run fine, so then if I drove it to the shop and came back to it, starting the engine again this is where the problem arises.
When it idles it is usually 1,000rpm and the engine shakes a concerning amount, if I raise it to about 2,000rpm the shaking stops but the engine has no power.
Does anybody know how to fix this problem? Or know what the problem could be because at the moment I have no clue, many thanks
