aFiFi
My dream punto 188
*S2000 199 i4 16v dohc engine
270 hp + vvt intake
Plus
*Twin scroll trubo +bov +wastage gate +turbo cooler
*Cold air intake + intercooler
*Catless header +center box + dual back box+mufflers
*cvt automatic transmission from 1.2 16v sporting sequential manual 6speed+speed gear-if fits or equivalent -+steering shifting pedals+ transmission cooler
*AWD system front +center +rear electronic diffrent
*air suspension system +struts
*4piston caliper front 330 disk brakes +4 piston caliper 300 rear disk brakes +hydraulic brake lines +ABS system +EBD+hill assist +tct device +esp+drive control -all systems from 188 abarth-
*tuning chip + ecu remapping
*dry oil sump +dry oil pump +oil cooler +oil catcher + oil pressure regulator
*rally sport fuel pump +fuel pressure regulator +rally mpi injectors+laser iridium sparks +rally spark plugs +sport coils
*15 inch wide ally wheels+spacers+split runflat tires
This is stage 1 handling + performance
To be continued...
270 hp + vvt intake
Plus
To be continued...
