aFiFi
engine
Alfa Romeo Giulietta (940) 1750 TBi 2014-
940B2000
83 × 80.5 mm
3.27 × 3.17 in
double overhead camshaft (DOHC)
4 valves per cylinder
16 valves in total
240 PS (177 kW; 237 hp) at 5750 rpm 340 N⋅m (250 lb⋅ft) at 2000 rpm
0–100 km/h 6.0 s
Top speed 244 km/h (152 mph)
Plus
oil
dry oil system -sump ,pump -
oil cooler
oil catcher
exhaust
decat alloy header -center box -back box double -mufflers -all alloy .
brakes
hydraulic brakes -punto
abs system -ecu -cables
drive control system-esp -tct- ebd-anti spin regulation -
2 pistons brake caliper front with large disks -1 piston rear
rims and tires
17 inch wide alloy rims with run flat split tires and spacers -
handling
air suspension
struts
transmission
6-speed Dual Dry Clutch Transmission FPT C635
plus
blow off valve
wastage gate
down pipe
turbo cooler
transmission cooler
inter cooler
tuning chip- piggy pack
regulators
that is the mechanical part performance and handling
interior and exterior tbc
:slayer::slayer::slayer::slayer:
940B2000
83 × 80.5 mm
3.27 × 3.17 in
16 valves in total
0–100 km/h 6.0 s
Plus
oil
oil cooler
oil catcher
exhaust
brakes
rims and tires
handling
air suspension
struts
transmission
plus
blow off valve
wastage gate
down pipe
turbo cooler
transmission cooler
inter cooler
regulators
