up and down is the only cable that snaps, left right never fails
Are you saying when in the driver seat, looking at gear stick
"Left to Right cable" is when you move gear stick left and right - sideways
and "Up and Down cable" is when you move gearstick between 3rd and 4th.
ENGINE COMPARTMENT MANUAL GEAR SELECTION PARTIAL WALKTHROUGH.
It might help someone, print it out and keep it in your glove box. This is what I have experienced today, but when yours breaks it may not work like mine. If you find like I did, that your gear shift is stuck in a gear like 3rd, First use the handle(see below) into position 2 you may have to use force, or have someone dip the clutch. Then check the gear stick, if it has moved a little, then if you have to, force the gearstick out of it's stuck position into neutral position.
Haynes Manual page 7A 2
Picture 3.2
In the picture there are 2 gear selector arms on the gearbox, one on the left (of the picture) and one on the right.
The right one is the top one on the gear box
"the top selector"
The left one is the bottom one on the gear box.
"the bottom selector"
The bottom selector has three positions 1, 2, 3
It also has
two ends the
bottom end is where the selector cable is attached
the
top end is a big block of metal which I will call "
the handle" because it is convenient for holding and selecting manually from within the engine compartment.
When the bottom end (the selector cable attachment) is in the middle , the top end (the handle) is also in the middle (position 2).
When the bottom end is pushed towards the wing of the car, the top end (the handle) is pulled towards the engine block (position 3).
And vice versa, when the bottom end is pulled towards engine block
The top end (the handle) is pushed towards the wing of the car.(position 1)
I found it easiest to grab the handle and move that.
When the Handle is in Position 1 that is 1st gear or 3rd gear (depending where you are)
When the Handle is in Position 3 that is 2nd Gear or 4th Gear.
I have found that putting the handle in position 2 (the middle) from within the engine comartment, enables you to go into the drivers seat and move the gear sideways into either 1st/2nd position or 3rd/4th position. And then pull the gear stick down into 2nd or 4th will enable the gear to be selected and it puts the handle into position 3.
I can then change the gear with the handle by moving the handle from position 3 into position 1, this will change it from 2nd into 1st, or from 4th into 3rd.
I wish I knew this yesterday, I would have saved my clutch.
I am curently on my own, so I cannot check the movement of the side to side gearstick and the resulting movements of the
the top selector.
And to see if it can all be done from inside the engine compartment. but the above should definately help anyone with this problem. I will update this to add the
the top selector. details when I can.
