Turkulainen
Hello Fiat owners. I have already read a lot from the forum about my problem but still confused a little. I own Fiat 2005 Punto 1.2 8V. The problem is that the abs lights up when I insert the key and turn it until the ignition and after I start the engine it briefly stays on until I start moving and then goes off when I take off. The abs pump kicks in and makes the sounds with the pedal vibrating and the brakes acting just as abs works usually. It all lasts untill I speed up to 40-55 km/h (25-35 mph) and then the abs light comes back again and the brakes continue working as conventional brakes. It all started a few days after I unsrewed the back seat to clean it at home. I took the car to the diagnostics and it gave C1046, C1047 and C1052 codes. The guy told me that the sensors are dead, but I couldn't believe they could die both at the same time. So I bought the vag com kkl+ fiatecuscan cable to try to check it myself and guess what happened, this little bastard connects to engine and airbag module but does not work with abs module. So I decided to check the sensors' resistance and compare them with the front sensor readings and it showed me around 707-717 oms. I read that it could be either the break in the wiring harness or the sensors or even the magnetic ring on the bearing. I went to the mechanic and they told me they are not sure and asked me 75 eur just to check this. I would like to fix it but I assume there is cheaper way at least to determine what is the problem. I would like to ask more experienced punto owners, what would you advice me to do? May be someone has the pin layout of the abs main connecter under the bonnet so I could check the resistance from the bonnet and guess it could show me if there is any problem in the wiring. Thanks a lot for reading and yes I live in Finland, where the prices for the servicing could just bite your hand off . Hope for your help.
