Old 02-05-2015   #1
CruxMea has donated!
Front strut and suspension
I wonder if someone can advise me. I'm in the process of changing the front springs and struts on my (2004) Punto 1.2 8v
I ordered the kyb struts and Springs and the large rubber top mount.
I managed to get the passenger side off today - but I noticed there was additional things on the existing spring which I didn't realise that I needed such as a upper spring cup (which is rusted) and also what seems to be a 24mm nut holding the rubber mount on the strut.
Do I need to take these off the existing struts or should they have came part of the new equipment I bought and are missing?
Or, do I have to purchase them separately? if so can somebody please point me to the right place.
I have to admit that 24mm nut totally threw me off as I only have ring spanners up to 20mm - I'm really annoyed - as I was on a roll and then I discovered this and then it started raining.
CruxMea is offline Reply With Quote Quote
Old 02-05-2015   #2
flisko has donated!
Re: Front strut and suspension
that nut on top of strut is 19mm, bottom nut near wheel is 17mm, bottom screw is 15mm, atleast on mk2, didnt knew mk2b got different sizes
flisko is offline Reply With Quote Quote
Old 02-05-2015   #3
That's correct the bolt in the engine bay is 19mm - I managed to get that off ok - but once I took the whole strut and spring out there was what seems to be a 24mm nut holding the rubber mount to the strut.
I have no idea what I need to do
Old 02-05-2015   #4
flisko has donated!
if you remove that bigger nut, spring will pop out and to put new spring in you need spring compressor
Old 02-05-2015   #5
I do have compressors - but do I have to reuse the big nut and existing cup on the old spring? - or do I need to purchase new ones?
And I guess either way I need to get a new 24mm ring spanner.
Old 02-05-2015   #6
flisko has donated!
dunno about that, never took them apart, i always just changed whole strut
Old 02-05-2015   #7
Yes you need to fit those bits missing from the kit onto your new strut ass, i not long fitted lowering kit to my punto mk2
Jjphoenix2k9 is offline Reply With Quote Quote
Old 02-05-2015   #8
Ok, cool
I will go about taking them off in the next day or two and fit them on the new struts.
Hopefully the weather will get better
Old 03-05-2015   #9
UPDATE:
Turns out it's a 27mm Nut - What a nuisance
Old 04-05-2015   #10
Hi Everyone,
Can someone please tell me what this rusty metal plate is called -as shown in pics 1 and 2 - and where can I get a replacement?
Also, I have triend compressing the coil and used an allen key and 27mm wrench and can't for the life of me take this top nut off - can anyone give me further tips - or am I better off purchasing an impact wrench.
Cheers,
CM
ID:	154258   Click image for larger version
Old 04-05-2015   #11
Finland
jte is offline Reply With Quote Quote
Old 04-05-2015   #12
flisko has donated!
i use 1 meter long round metal pipe for bolts that cant be undone by my brute hand strength which is quite rare
Old 04-05-2015   #13
Cheers Pal
That's what I'm looking for - Thanks again for the reply
Old 04-05-2015   #14
I tried with a breaker bar - ring spanner - but the whole strut spins with nut as well as the whole strut assembly - need some sort of vice to hold it.
Old 04-05-2015   #15
varesecrazy has donated!
Quote Originally Posted by CruxMea View Post
put the nut from other strut on the threaded end, back to back as lock-nuts,
then put spanner on the outer one as you undo the 27mm one,
should hold it enough to undo things
do get the compressors on 1st though
I did a guide in panda section - may help..,
Charlie
(T) Front Suspension Strut Help paddycento Stilo 2 06-04-2014 18:01
(T) X2/50 front suspension strut Steve928 Ducato 2 05-11-2012 09:52
(G) Front Suspension Strut DasArab Punto (Mk2/2b) 9 04-12-2011 21:46
(T) Front suspension strut location osmodia Punto (Mk2/2b) 0 19-04-2009 10:38
(T) Front suspension strut location KwikPhix328 Punto (Mk2/2b) 3 18-01-2005 11:20
