Technical heater blows fuse
Swindon
So my cars interior fan fuse (30amp miniblade) blows whenever I turn it up to setting 4 :confused:
The fan sounds weaker on settings 1-3 and if I give it a little smack whilst its on setting 1-3 I think I can hear the frequency of rotations getting faster and slower (not constant).
About 6 months ago I did the interior fan fix because it was squeaky. I used a few drops of 3in1 and it certainly rectified that particular problem. Could this be a result of that?
Do I just need to replace the whole unit?
Sidelights do not come on and connectors have been disconnected to check for burnt wires but I haven't found anything.
I have mk2b 8v no air con.
I suspect that the fan is either
partially seized, or there is a serious wiring issue as a result its just pulling excessive current
The fan is held in with 3 fasteners, they vary from philips to 5.5mm hex's
The resistor pack is the common failure by eating the connectors and burning the wiring
Its literally connected to the wiring loom
This blog i made for my portfolio may show you something to look out for
Ziggy
So here's what the wires to the resistor pack look like... It looks like theyve got a little warm.
Well I checked the plastic for heat and it didn't look too bad. On further testing though, those wires were definitely getting very hot when the heater was on setting 3 (setting 4 would blow the fuse).
On removing the fan and spinning it by hand I think it must have partially seized as it doesn't spin very freely.
I got a 2nd hand fan from scrappy and it all seems to work ok. The wires no longer get hot on settings 3-4 and it doesn't blow the fuse anymore. When the fan seized up it must have been drawing too much current when trying to turn on the higher settings???? So I guess that's why they look like they'd got hot.
Thanks for the help guys
The resistor pack resists the flow of electricity to give you the variable speeds
speed 1 is very very resistive
2 is very resistive
3 is resistive
4 is free flowing (almost direct battery current)
Now on 3 and 4 it spinning quiet fast and pulling some amps, now stick a binding motor and hell - it now pulling more amps, which on speed 3 its resisting very much todo
Oh wait - the fuse has just said to much to much
I've tried to see if the bearings are replaceable, but i got the motor out and its sealed pretty much.... sigh
Ziggy
