Technical removing electric window mechanism
anyone know how to remove electric window mechanism, cant see any bolts or anything, there are only 3 bolts on the motor itself
<Ignore this> that picture is completely useless.
Oldhammer is trying to help but you're looking in completely the wrong place<Ignore this>
edit: looking at that picture you've already removed the bolts that hold it in !!!
so what are you actually asking ? you feed it out through the hole in the inner door skin
flisko,
you will need to remove the full mech,
this will involve removing the door glass,
don't try removing motor from mech inside door,you will rip you hands to peices.
the mech is bolted to the metal of the car door,
your pic is no use to show where bolts are located,
