garysmith21
- Jun 25, 2012
- 24
- 4
Got round to trying the 'IV drip' tonight.
Firstly, I disconnected the filter to HP pump hose at the filter. I then added a separate piece of hose to the filter into a bucket and turned on the ignition - good spurt of fuel for the 3ish seconds the LP pump was doing it's thing. Doesn't appear to be a problem on that side of things.
I then connected the HP pump hose up to my clean supply if diesel and turned the car on. It started for about a second and then died. And then wouldn't start again. The bucket by this point was getting pretty full!
This looks like an HP pump problem doesn't it?
What I had failed to mention before is that when it was starting, I then had to wait 5/6 minutes before getting it to start again.
What I'm thinking now is that the HP pump was being completely emptied of fuel when the car was running. It then wouldn't start again for 5/6 minutes until it slowly filled up with fuel. Then it would start and die again.
Does this definitely sound like an HP pump problem?
Or could it still be something else?!
