FIAT Auto Specialist Team
Thread Tools
Old 15-10-2011   #1
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
having a Hot Air feed this winter
in the summer you want a cold air feed, as the warm air is less dense then cold air
its a well known fact
since in the winter - cold dense air is been sucked in - the car has to fuel more to compensate to give a good fuel to air ratio
How about for the winter swapping to a warm air feed?
as surly it means it'll use less fuel - and since warm air fed in - it should help the engine warm up a little quicker
So possibly Getting a Hot Air Feed from Near / around the Mani-cat could save fuel this winter? Surly you only need a little pipe to just take it from A to B from the stock airbox?
Any thoughts on weather todo it or not?
ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 15-10-2011   #2
dotdesign
colinf1 has donated!
Ireland
Re: having a Hot Air feed this winter
I think the hot air pipe from manifold is only to help with cold starting, helps get the engine up to tempurature quicker on cold mornings.
I think it would be better having a cold air feed all the time...
colinf1 is offline Reply With Quote Quote
Old 15-10-2011   #3
Quote Originally Posted by colinf1 View Post
I found my car sits for ages on the cold line - taking a few miles to start showing signs of warming up
so Surly giving it a little Hand will help esp with fuel on start up
I know cold air is the way forward - but will hot air running Be a problem? It'd be no different i believe if you ran a k&n filter ontop of the engine?
might take a few ponies away, but its wet and cold - you dont need more power
Ziggy
Meet Bumble-Bee
Old 16-10-2011   #4
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
I think your theory is sound. Just needs to be tried .
ChrisUK is offline Reply With Quote Quote
Old 16-10-2011   #5
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
On all EFI engines, the correct fuel/air ratio is calculated by the ECU using information from the engine temperature, and air inlet temperature sensors. If you were to "fool" the ECU by introducing hot air at the air inlet temperature sensor while the engine temperature was cold, it's likely that insufficient fuel would be injected to compensate for fuel that condenses on the cold cylinder walls. This could give you poor starting and poor driveability during the warm up phase.
Depending on the complexity of the OBD system, it may also generate an "implausibility" fault code.
Should be easy enough to rig something up on a temporary basis to test your theory though.
The purpose of the hot air pipe (activated automatically or by a manually operated Summer/Winter lever on the air filter inlet of older cars) is to prevent ice crystals forming in carburettor venturis and some SPI injector housings. It doesn't help with cold starting.
If you think about it, when starting the car, the manifold, and therefore the air around it would still be cold so there would be no advantage.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 16-10-2011   #6
m20b25 has donated!
Ireland
Quote Originally Posted by Davren View Post
Essentially to prevent something like this
OP I'm sure Fiat factored that aspect when designing the car in the first place
The ultimate driving machine, the real M20B25
"Ride me sideways"
VAN-dalised Bravo
Small, fuel economic, environmentally friendly Alfa
I am this gombeen
m20b25 is offline Reply With Quote Quote
Old 16-10-2011   #7
Yes soon as the engine is starting - its Running cold all around
but really takes about 30seconds for the engine to emit enough fumes to heat the mani-cat up a little bit
if the engine then started sucking in that heat as well - surly it'd okay
I realise it used temp sensor and Lamba to tell what to mix up
But surly if the car is sucking warm air in - it knows that?
So it knows less fuel is needed?
Ziggy
Meet Bumble-Bee
Old 16-10-2011   #8
Brendan W has donated!
Ireland
At the end of the day it's all about mass - getting as much air in as possible with the correct mass of fuel. Miles per kg makes more sense than miles per litre.
Induction systems use MAF mass flow meters and turbo inductions use coolers to get the density up so there is more air in the cylinders.Heating the induction just reduces the power available and efficiency of the process. Fuelling systems add whatever is required for the mass of air in the pot.
In the old days you had to switch over to warm air for the winter to avoid carburettor icing and you always lost three or four mpg as a result. If you forgot, the car would just die on the open road.
Brendan W is offline Reply With Quote Quote
Old 16-10-2011   #9
So really - its not worth it?
Shame - as the idea is great esp to save money, but really when its broken down it just makes it worse?
maybe just worthwhile unclipping the Nozzel off the end and leave it there, that way it gets only a touch wamer and we'll have to see if that work or not
Ziggy
Meet Bumble-Bee
Old 16-10-2011   #10
Ireland
Never trust theory - do it yourself and see what happens - then your talking from experience. It's not beyond the bounds of possibility that a little warming could improve things - only one way to find out.
Old 17-10-2011   #11
Miss my old punto :(
Butcher's Avatar
Butcher has donated!
whats the reason behind people putting there standard air box back on in winter?
and keep there gsr untill it gets warmer again
Punto 1.2 Active sport
Corsa 1.4 Sxi
Audi TT 225
Astra 1.9 Sri
Seat Leon Fr
Butcher is offline Reply With Quote Quote
Old 17-10-2011   #12
thats Jip Zero
jip0's Avatar
jip0 has donated!
Shape Shooter Champion
Quote Originally Posted by Butcher View Post
coz you use a ton more fuel
Looking for Mk2 601 nero black front bumper PM me
The Car
Quote Originally Posted by custard View Post
get a pic up,I'll tell if its big
Quote Originally Posted by Kier View Post
I rather like the look of the wood :
jip0 is offline Reply With Quote Quote
Old 17-10-2011   #13
Moderator
ChrisUK's Avatar
Trader Rating: 1
I never noticed the difference.. Did use a little more but then I had lots more power.
People are paranoid about sucking up water / slush which is plain rediculous.
Old 17-10-2011   #14
You will get a more efficient burn using cold air as its more dense so contains more oxygen mass than warm air. Apart from on a very cold engine, this more than out-weighs the thermal losses.
DaveMcT is online now Reply With Quote Quote
Old 18-10-2011   #15
Trader Rating: 5
fingers99 has donated!
You're more likely to save a wee bit of money (and improve engine life) by blanking off some of the radiator.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Thread Tools
(T) Engine running hot and lack of hot air in cabin Ucof Uno 108 09-06-2010 14:34
run a washing machine on hot feed only? custard Leisure Lounge 23 17-12-2007 21:29
