having probs with misfire as people know, and proberly sick of me asking questions, just dont know who else to ask, hence asking u experts :worship:
Just took a reading from my lambda sensor when engine was hot, fan kicking on and off, reading in volts was steady 0.007 area. and in ohms 0.7**
(** means various numbers)
Just wanted to know is this normal. readings were taken with a digital multimeter set to 2v.
Also lol when I did my head transfer, I swapped inlet manifolds and use the same gasket, could this be leaking air in. missing at idle, hesitation when driving/poor response, and when engine is warm, if i come to a stop at lights, after I've pressed the clutch down, the engine dips to the needle rest on the rev counter and sounds on the verge of stalling for about 10-15secs then recovers but still missing, also happens when I start the engine when hot.
coil's swapped no difference.
new plugs no difference.
leads less than 2months old.
new engine coolant sensor.
swapped throttle body no difference.
timing, more than 4 times tried, no difference including flywheel marking.
any help appropriated.
thanks and sorry for bugging, cars just getting me down as i cant seem to find the fault. and at the moment im just throwing parts at her and seeing if i get lucky
Dave
Dave
