i'll read through the thread later.
vehicle details???????
Why do you need a new head? I have a head from a 1.2 8v punto. Blown piston rings but head should be good!![]()
I have no idea. Someone else would have to confirm this![]()
knocking or tapping?
this was my engine before hand, no misfiring, or near stalling at idle, just knocking on camshaft.
which when i took the head out the bearing cups had scratch marks on them.
but you say it ran ok except the noise? if this is the case then (assuming you have connected all the sensors back correctly and are using original sensors) the fault is in the new head, skimmed/gasket thickness etc
Something odd going on -
0.07 Ohm is almost a short circuit. 0.007 volts is pretty much zero so something odd is going on.
Unless the engine is stone cold on a cold day, that exhaust picture is not good. Include the eyes stinging smell makes me believe you have coolant down the exhaust pipe.
It could be the head gasket or a crack on the head or in the block.
Coolant will also affect the Lambda readings.
