Old 22-01-2005   #1
Punto Sporting problem
Can anyone help? I've had a problem with my Fiat Punto Sporting (W reg) for several months now and I can't find a mechanic who can sort it out.
This is what happens. I'm driving along and when I brake the car 'thinks' it is in reverse. The R signal flashes up on the dashboard (well, it sometimes alternates between D and R as though it is 'confused' about which gear it is in). In addition, the beeping sound that I get when I'm actually in reverse goes off, and continues until I take my foot off the brake. The gears themselves are actually OK - the car just seems to be getting the wrong signal. I have taken it to 3 mechanics and these were the results.
1. The first guy changed the brake switch and said he did some work on the electrics. The problem returned within 3 days.
2. The next lot, a Fiat garage in Catford, said the car need a new ECU (and attempted to charge me a small fortune). However, my friend spoke to an ECU specialist in Greenwich, who said this was not an ECU problem.
3. The latest mechanic thinks the computerised system is out of kilter and just needs to be reset (by a Fiat specialist).
As you can imagine, I really don't know what to do next. The problem can't be so complex that it is unsolveable. I definitely don't want to spend any more money until I have a good idea of what the problem actually is. Any help would be greatly appreciated.
Many thanks,
Mary Cochrane.
Mary Cochrane is offline Reply With Quote Quote
Old 22-01-2005   #2
Trader Rating: 10
dave has donated!
Re: Punto Sporting problem
hmm dont know where it is on a mk2 punto but most cars have a switch thing that moves with the gears that tells the rest of the gubbins what gear you are in, its on top of the gearbox on a mk1 i reckon it could be just the plug on that is loose, or if its like a mk1 needs the 2 mounting bolts loosened and turning slightly.
EDIT sorry forgot to say, Welcome to the forum
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 23-01-2005   #3
Thumbs up Re: Punto Sporting problem
Have anyone looked around the area of the brake pedal to make sure it is not physically rubbing or pulling on any wiring when pressed?try this hope its the answer.
diamond is offline Reply With Quote Quote
Old 23-01-2005   #4
arc
this is where i stand
arc has donated!
sounds like a short, i know on cinqs the brake and reversing lights are on the same circuit, dont see why it'd be different here.
just for a test.. take you're brake light bulbs out and test it.. humour me..
if that doesnt help, pull the reversing bulb out too, and if not - get a haynes manul and trace the wires for each circuit and check anywhere where they could short.
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 24-01-2005   #5
Thanks for replies to my problem. Will test out possible solutions and post results.
Old 24-01-2005   #6
Forgot to ask - where can I get a Haynes manual? Thanks.
Old 24-01-2005   #7
Trader Rating: 10
dave has donated!
Quote Originally Posted by Mary Cochrane
any car accesory shop, or www.haynes.com
Old 26-01-2005   #8
If there is a MAKRO store near you go there they are cheap on car stuff surpriseingly and loads of people have the trade cards through their work places
Mincento Autospares-For Fiat and Alfa romeo spares, message via PM and ill get back to you
The younger modder is offline Reply With Quote Quote
Old 28-01-2005   #9
This is to say a huge thank-you to all the people who provided possible solutions to my problem. I printed them out and took them to my mechanic and he found that it was actually an earthing problem (and the brake pads needed sorting). I'm picking the car up today so hopefully will be OK. Any ideas on how much this type of work should cost?
Old 28-01-2005   #10
thefishdude has donated!
Balloony Champion, Bee Wars Champion, Submarine Champion
well break pads are pretty cheap. earthing problem?? that is quite random so hard to put a price on what heis actualy going to do. as it sounds like it wuld be mainly his labour you pay for that one.
2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm
thefishdude is offline Reply With Quote Quote
Old 12-02-2005   #11
Forum Moderator
T14086's Avatar
T14086 has donated!
Speak of the devil I had one of these problems today,traced it to faulty earth at rear light cluster
One to look out for in the future!
Old 14-01-2018   #12
India
Download car Manuals PDF files for repair, maintenance and wiring.
Manualsco
manualsco is offline Reply With Quote Quote
(T) Solution to Punto 75 mk1 Engine Problem Tziallas Punto (Mk1) 8 10-09-2010 08:17
(T) Punto cooling problem GaryRichards Punto (Mk2/2b) 6 29-10-2007 14:48
(G) punto sporting alloys wanted djkevs_unoturbo_mkII Punto (Mk2/2b) 11 12-10-2005 00:49
