Old 28-12-2009   #1
Electrical Problems
I have owned my 2000 punto (mark2) for a few months now and everytime i go to start the car up its dead, i have tried a new battery on the car and that went dead after the first drive. so i thought it would be the alternator so i checked that with the multi-meter and all was working in order, does anyone know what i should check?
And also on the instrument cluster i keep having a light apear underbreaking and i looked in the manual and it said i light would be out, but got someone to look and they was all working.
any ideas?
all appreciated
Copeycfc is offline Reply With Quote Quote
Old 28-12-2009   #2
Trader Rating: 5
fingers99 has donated!
Re: Electrical Problems
The light is probably the brake warning light. Generally it means your brake fluid is low. Check that.
For the battery issue, try peering under the bonnet while someone tries to start the car. Any orange flashes around the battery, starter motor or earth points indicate the source of your problem.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 28-12-2009   #3
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
If your brake fluid is low, and there is no leak then it will be time to change your friction material. The fluid takes up the space of the missing material.
However, the same light also comes on with the handbrake, make sure the switch is sitting correctly.
If its not that light, there is a simple rule of dashboard lghts. If its red, stop.
SPD
Old 28-12-2009   #4
i have checked the brake fluid and its like brand new and at the max point, and its only recently had new brakes fitted onto it has i did have problems while braking and it was getting scary. i have also checked along the break lines and there are no leaks and no buldges.
i got someone to start the car while i looked underneeth and there was no sparks anywhere.
also looking for the switch behind the dash for the light problem the temperature gauge switch has stopped working and i never touched anywhere near that area.
thanks for your sugestions.
Old 28-12-2009   #5
Trader Rating: 5
We need more information about which light came on.
How did you check the alternator with the multimeter? What were the results?
Any extra ICE?
I'm still inclined to suspect an earth fault. Try a single jump lead from the battery -ive to somewhere near the starter motor.
M12 fund 20
Old 28-12-2009   #6
the car has a non-standard stereo in the car. was fitted from one of the previous owners.
i dont really know how to explain about the light because the car doesnt get stored at my house and the books with the car, but if i remember correctly the manual says that its bulb warning light, and it only happens under braking.
Car has a factory fitted subwoofer.
ill check the earths next time ill be with the car which will be tomorrow.
with the multi-meter on the battery was 12.6volts as standing still. volt drop was down too 10.3volts. and the battery went up to 14.2volts.
alternator reads 13volts when running.
Old 28-12-2009   #7
Trader Rating: 5
13 volts suggests an alternator issue -- should be more like 14 - 14.5.
I think the sub is probably draining the battery, but I'm no ICE expert.
M12 fund 20
Old 28-12-2009   #8
ohh okay, but the subwoofer is factory fitted though but i think im just going to have to check the earths and alternator again, thanks for the suggestions
(T) Electrical problems gentil303 Coupe 3 24-11-2009 23:08
(T) electrical problems polerafon Uno 0 21-10-2008 14:23
(T) Electrical Problems aj287 Barchetta 8 04-03-2007 23:11
(G) Electrical Problems Alan.D Panda (Classic) 11 05-04-2006 22:48
(T) Electrical Problems! arc Cinquecento / Seicento 2 02-05-2005 13:18
