My wife has a Punto 55 N reg. Lately it is very reluctant to start on some but not all occassions. As the key is turned to activate the starter there is just a click from under the bonnet and the starter does not turn. It seems like a battery problem but the battery is fairly recent and I have also tried charging this up. Reading through some of the posts I have noticed problems cited with the ignition barrel, is this likely? I am pretty sure I can rule out the battery as the car may start perfectly Ok in the morning, then play up at lunchtime and then start perfectly at night of the same day!
I need a quick diagnosis as these things always need to be sorted at the weekend.
