General Lighting problem HELPPP!!
Josh Tugwell
Peak District
Hi
I have a punto evo
So my corner lights don't turn on. I've replaced the fuse and the bulb and was wondering what colour the power wire is for them on the plug for the head light.
Josh
Have you tried replacing the relay ?
There are also an additional 2 relays else where under the bonnet to control the tuning lights feature. Basically fiat hacked the turning lights into the already existing grande wiring loom making this set up a bit of a mess.
On of my relays for the passenger side turning light had fallen off its bracket, was hanging upside down and had filled with water. It had completely rusted inside and the relay had fallen apart. The result was neither the fog light or turning light on that side would work.
That's not good [emoji28]
I've tried that too that's why I was wondering what colour the power wire is so I can trace it back
Thank
Josh
Ig you mean corning lights then I have the same problem.
Only now have I had time to start looking at it in detail.
Where are the relays that power the cornering lights?
I stuck a copy of MultiECUscan on my car, and the systems all show ok.
No ProxiAlignment was needed so I left it alone.
I've tried looking for a fuse/relay diagram online, but all the ones I find are for those cars with a fuse box in the rear, I don't have this.
Located where..??
New one on me.. :eek:
Charlie
Evos have a fuse box/relay box in the boot, behind the left wheel arch, and behind the carpet of the boot. Unless you have a high end model then there’s not a lot in that fuse box, also this fuse box has nothing to do with the cornering lights as per the initial posts in this.
